A neighbor gave me his backpack blower with the seized piston. He put straight gasoline in the tank without adding oil. I was able to free the Piston but it won't start. Spark is good and I hit it with starting fluid but no go. It has a good spark so I was surprised when the starting fluid wouldn't at least turn it over for 5-10 seconds. Compression is only 65 PSI. Is that too low? After doing some searches I've seen compression numbers around 120-130. Does anyone know what the compression is supposed to be for this blower?
Thanks
Slash
Thanks
Slash
