JohnCardin
- May 27, 2014
- 24
Ok, not sure if this is an issue or not, but figured I'd ask others. When starting my now 3-hour RSD, If I pull up the choke when trying to start, it won't start at all. If I push down the choke it will start and run just fine. I see the linkage moving what I suspect to be the choke on the engine.
Is this something I need to worry about?
-John
Update: Just looked at the manual and it says to put it at 1/2 throttle to start. I had not been doing that but will try this week to see if that's the issue.
-John
