Have this Roper 16hp(on the fender) but has 19hp Briggs Id plate thrashed need info on what it may be,also first mower with this IC engine no OHV plate so have to pull a plug to start then reinstall to fire up other head,assuming is valves.Any info other then take battery out and pull new mower would be appreciated..Thank You
