When I try to turn left on a uphill slope the right transaxle does not work as it should.
V vrb Forum Newbie Joined May 30, 2014 Threads 2 Messages 4 Aug 31, 2024 / Right transaxle low output #1 When I try to turn left on a uphill slope the right transaxle does not work as it should.
A Auto Doc's Active Member Top Poster Of Month Joined Sep 7, 2024 Threads 1 Messages 51 Sep 7, 2024 / Right transaxle low output #2 Sounds like a worn drive unit if this is a zero-turn model. What are you working on?
