I have Craftsman rider model 917.270821, and it won't start. OK, here is what I've done so far.
The mower won't start using the ignition switch, but will when I jump across the posts on the starter solenoid.
I've replaced the solenoid with two new ones, no change, will only start when shorted across the posts.
The fuse is good, wiring looks fine, battery and cables OK.
Is it possible that the only problem is a bad iginition swithch?
When I short the solenoid posts and the engine starts and runs great, I can kill the engine by turning the ignition swithch off. But engine won't restart with the ignition switch.
Please give me some advice. New solenoids don't help......
Jim
Jim
