Reverse switch
ZAE
on a MTD riding mower on the hydro-static lever there is a switch that is a safety reverse switch. Part #725-1713. Does anyone know if this is a normally open or normally closed switch? Thanks for your help.
The way to find out it the check for continuity with button pushed and not pushed. Repost back you findings and I will tell you what it is supposed to be.
