Now that I have installed a new pump at my well, I am trying to restore the old Goulds Jet Pump, 1 HP. It appeared to be "frozen" so I took it apart and it had must rust inside it. is there a way to remove the rust from both the armature (stator??) and rotor surfaces? Sand paper? What grit? It is an old Goulds pump shallow well, jet pump. Cast iron impeller.
Thanks, people.
Thanks, people.
