charles manson
My Lawn Boy is a model 10323-8900001 & Up Serial# 8921298
This newbie is trying to replace the drive belt on the self propulsion assembly. I don't see doing that without removing the engine from the housing. I removed the blade, collar and five or six bolts and lifted the engine up and out of the housing. I assumed the engine separated from the plate that positions the engine over the housing. With the engine removed, the plate remains attached. I dont see a way to separate the two and I don't see a way to get the new belt on the pulley without removing that plate. I would sure like the advice of those with experience. My research says the part # of that replacement belt is (92-1043). Thanking you all in advance, Charles
