Jinzo Ningen
 - May 27, 2011
 - 44
 - 127
Both of deck frame tires on the 72" mower I have are losing air and require pumping with every mow and the diamond tread is about worn off.  I searched and found Marathon Flat Free Tires thru Northern Tool. The stock tires are 4x10 and these are 3.5x9 so I hope that won't screw up the cut. Anyone else running these? I didn't want solid tires that might cause my deck to bounce all over the place on bumpy patches of lawn, so I sure hope these will work. With any luck they'll last for the life of the mower.
