You don't give us enough info to say go or no go. Things I would need to give you an opinion. Part number of the original and brand and part number of the replacement. Pictures do not show me two things which I would need and would be hard to get. Don't know if the mounting hole spacing is the same, both horizontal and vertical. Second and more critical, is the arc angle the same on both coils? Finally, is the pick coil mounted on the same side of the coil, when the coil is mounted on the engine? Can't really tell on the replacement coil.
