Repair/Purchase Scam
Resqguy
I took my riding mower into a local repair (and used equipment dealer) to fix a (brand new) bad oil seal. I had just fixed a governor problem, but was just tired of working on it. The repair guy made no secret that he wanted me to trade mine in on one of his repaired used mowers. I told him just to replace the seal and get back to me. I went by today and he said that the leak was fixed (it was) but the governor was broken. I know that is a lie because I just fixed it - he probably just bent the spring to make it run fast.
BTW, my old crank seal did not leak before I replaced it with a new Briggs one.
The guy wants $250 for the seal repair, which I think is fair. Alternatively, he wants $600 and my unit for a rebuilt riding mower. Mine is a 46" this one is a 48". They are about the same year but mine has been stored indoors. Mine will need a new battery in the spring, but has new mandrels, blades, carb, and belts.
I'm wondering if anyone has run into this scam before? Did you trade? There aren't any other reputable mower repair places in my area. The last place did an oil change and left the filter loose to leak oil all over my garage floor.
My gut is telling me to pay the $250 and take my mower home, but I would still have to adjust the spring and replace the battery next year.
The other unit is a 48" with 3 blades, my 46" has two. The 48 also has the fuel filler by the real wheel where mine if under engine hood.
Thoughts?
Husqvarna 46" with Briggs INTEK 22.
Well I had a new customer a couple years ago that a local Hustler dealer tried ripping off on a repair. They told the customer they needed a new $3000 engine. So the customer came to me for a second opinion. It turned to be a $300 where the head gasket had to replaced. Note the engine was going through lots of oil but had plenty of power.
BTW crank seals are not that hard to replace, unless, it has a stuck on electric PTO clutch and the tech doesn't know what they are doing.
Resqguy
I'm assuming the seal replacement would require that the motor be removed. Not too bad but I wasn't in the mood to go through all that again.
Well most times it don't though the engine oil is usually drained.
Forest#2
You asked
Thoughts?
After someone leaves a bad taste in my mouth I do not return for a 2nd taste test.
I have a policy of
strike one forgive,
strike two shame on you,
and strike three shame on me.
I seldom make it to strike three.
Tiger Small Engine
Thoughts?
I don’t think so much that this is a “scam” as the guy is simply trying to turn a larger profit. He is offering a product, assuming it runs and mows right and everything is working, and taking your mower as part of the transaction. It is also hard to determine the fairness of cost without seeing the mowers in person for the shape they are in.
