I viewed the linked YouTube info and looked around here - so this is more of a clarification than lots new.
The white stuff is white Lithium spray I initially used to loosen things up.
Then I read the links and posts here and recognized the problem.
If I understand correctly I need to find a way to insert a bushing where the shaft passes through the soft metal to keep the gear from moving?
Or, could I add a spring to pull the gear toward the teeth?
