[ATTACHREUSE][/ATTACHREUSE]
I have a Powerstroke Pressure Washer that I bought from Costco. In the middle of using the machine, it stopped cold. As if I hit the kill switch. I replaced the spark plug. I attached the Harbor Freight spark tester between the plug cap and plug and the light did not light up. I want to open up the power washer to troubleshoot the coil and the kill switch. The problem is I do not know how to get the plastic top off. There are two screws on the back of the cover that were easy to remove. Near the front the cover is attached to the engine from the bottom. Any idea how to remove this plastic cover without damaging it?
