tom3
- Apr 9, 2018
- 25
- 1,579
Might not always work but did for me. Wanting to check exhaust ports and muffler. Took off blade, put nut back on flush, two jaw puller tight enough to start bending flange, spayed with loosener stuff, put some heat on it, hit the end of the puller screw a couple times, wouldn't budge. Didn't want to overheat the crank and ruin the seal so I quit that. Searched here on the site and noted that the shaft is tapered. Humm.... Sort of like a tie rod end or balljoint. So I got a hammer and a drift (punch with a flat end), put the end of the drift down behind the flange on the side of the collar itself, and gave it a couple good whacks. Flange/collar popped loose. Also used a big hammer to buck the opposite side to keep from maybe bending the crank, just as a precaution. So if all else fails, get out the hammer.
