HOW DO YOU REMOVE THE TRANS FROM A SCOTTS 1642S
M mreddie Forum Newbie Joined Mar 31, 2012 Threads 1 Messages 1 Apr 26, 2012 / remove trans from 1642 #1 HOW DO YOU REMOVE THE TRANS FROM A SCOTTS 1642S
SONOFADOCKER Well-Known Member Joined Jun 19, 2011 Threads 5 Messages 400 Apr 26, 2012 / remove trans from 1642 #2 Normall only four bolts hold the rear to the frame . Unhook drive belt and any linkage . This is a simplicity I did this morning
