Remove GXV140 from Self Propelled and Install on Non-Self Propelled Mower?
shanker
I've got two Honda HR215 mowers...one is a newer self propelled (with a bent shaft but works great) and the other is a non-self propelled with a blown engine.
I'm buying a new engine to put on my self propelled mower and was wondering if I can install the old engine on my older mowers frame?
Everything looks like it'll line up right and work, but the only difference I can find is where the shaft comes out of the block for the transmission. Can this shaft be removed and the hole be threaded & tapped?
What's the serial numbers off both mowers? If you can get me those, I can check our service database and also speak with an engineer.
