CrawlingKane
- Jun 2, 2018
- 2
I looked over the forums and see that there are people with similar issues but not exactly.
It all started with the fuel in the oil crank issue - I replaced the fuel pump and now that problem is over with.
My Regent 16hp will click when the key is turned into the start position but it will not crank over, things that I have tested and worked on:
Battery is at 12volts
I get 12 volts to the starter when in the start position. I get continuity to everything.
Replaced solenoid
Check key switch and it's crappy but I get continuity on all switches locations
I have taken all of the safety switches and I get continuity to all of the plugs, except the Green/Yellow wire where one of the brake pedal switches are I do not get continuity and there is a safety switch that turns the circuit off not on when pressed.
I believe the problem is with the Green/Yellow or the Purple/Tan? wire. But I don't know for sure
Also I have use a different battery to jump the starter and it will crank over....
Any other ideas? What am I missing?
Thanks!!!
Chase
Replaced solenoid
Thanks!!!
Chase
