Richie F
- Aug 8, 2019
- 20
- 281
Have a RedMax edger BCZ260TS (967194302)
Was given to me with no knowledge of it's condition/problem with the cylinder off.
Piston and cylinder wall looked good and could turn the engine over by hand with no issue.
Installed new rings and honed cylinder and assembled.
Now the question:
With the plug out I can pull it over normally like any other trimmer/edger but when I install the plug it's like pulling over a chainsaw. This is without the coil wire hooked to the plug also.
Checked muffler for blockage(found good) and that the coil pickup was not dragging on the flywheel.
Piston is not contacting spark plug also.
Compression after doing rings is 25 psi but yet trying to pull it over feels like it's "150".
Give me ideas and I'll answer you back.
Now the question:
