rednucleus
- Apr 16, 2022
- 21
@Auto Doc's I am sure this is the oem stator - FIL kept all receipts and wires have original paint. Checking black wire to block is open for resistance and no ac or dc volts found. Only reading I get off black is half the ac volts when touched to the other stator yellow wires vs the yellows together. I think I will get the regulator that @StarTech recommended, ground it to the block and cap off the mystery black wire.
