Rebuild kit ?
Cubby 18.5
Hey folks
New to this . I am on the process of rebuilding a briggs 18.5 engine. Looking forva good parts source for gaskets, piston rod and connecting rod .re using 1 that's good . Any help greatly appreciated
Thanks all
My recommendation is to go through your local repair shop. That way you will gain two things while working on your project. First, you will know that the parts you order, are the correct parts you want and needed. They can double check your part numbers or help you identify which parts you may have forgotten about. Second, you will have a local source for future questions and help. Most good shops are glad to help out customers who get their parts through them. Yes I know it may be a little more expensive than fleabay or Amson, but in the long run turns out to be cheaper.
artemjemmy
Hey folks
Thanks all
Just to ask, why exactly are you doing a full rebuild?
