Wallet is already out! Have been able to locate all the parts I need EXCEPT: Plenty of 1 over rings but no pistons, or 2 over pistons but no rings. My block has never been machined so I can use either if I can source them; or if there is some other make of piston that can be used/modified for use, I am willing to go that direction. The Tiller requires the Tecumseh engine because it has the extended cam shaft to use for reverse.
RANDY
ps. Tecumseh OEM numbers: Piston, Pin @ Rings .010 34528 Rings only .010 32596
.020 34530 .020 32597
