Mooch,
I've ridden all of the Hustler mowers as the block I live on has all of them. Everybody was trying to talk me into the model they owned which is normal of course.
An elderly gentleman (yes, even more so than myself) across the street has a Fastrack and the only thing I like about it over my RSD is the ease of setting the mower deck height and a tiny bit of speed. Other than that, I can't find any differences between the RSD and the Fastrak. The hydros are exactly the same with the exception of the third valve in the hydros that makes the 2800 hydro a 3100. His Fastak isn't any less sensitive than the RSD though. His does have six gallons of fuel capacity. Mine only has 3 gallons originally. 4 gallons since I raised the fuel tank ventilation hose to the fuel cap level allowing the two upper chambers to fill without pushing out fuel. By the way, only thing is, he never runs it faster than about a mile and a half to maybe close to two mile per hour. Wears me out watching him. lol.
I was wondering if you can tell me other differences I can't seem to notice. I like my wider tires, I like my engine guard better, I like my muffler better as it is quieter with a dB meter, and both seem to control exactly the same to me.
Even the X One and the Super Zs on the block all handle the same and mine rides better than all of them now since the flex forks were added along with the suspension seat kit.
Only two things I see for the Fastrak over the RSD is the deck setting device and the extra hydro valve. I don't mean this to sound or look sarcastic, I just can't see the extra expense and not gain anything. My lawn is the largest in the neighborhood and looks exactly the same as all the rest and I've got the only slum mower on the block, apparently. I know everything is taste and in the eye of the beholder. Just curious if you can actually feel or find anything worth the difference in price. I think both are grossly overpriced personally. lol
Thanks in advance,
Max
Hey Max. No sarcasm received, you make very good points and I think it depends. If what you've got is achieving the result you're after, then why would you need more?
I was the OP in the long-winded thread on the Raptor SD cut quality from a couple of years back. I bought my RSD 4 years ago, used it for a bit over a season, and was disappointed with how it was cutting on my lawn. I demoed the Fastrak and noticed an immediate improvement in cut quality. As mentioned above, I felt the control was slightly smoother, but that was not something I ever felt was 'bad' about the RSD. I think the deeper deck and slightly different discharge configuration made a substantial bit of difference in how it cut and discharged. I should say I have pretty high standards for cut quality, a relatively large yard (1.5 acres), and turf that grows very fast, and this was my sole reasoning for the upgrade. I was able to upgrade for only a couple hundred dollars loss on the RSD.
I seem to recall a lot of criticism at the time about my expectations for cut quality in that thread. Even after the upgrade, I still go back and forth about my impressions of the Fastrak. Depending on the time of year, growth situation, etc., there are times where I feel the Fastrak can't keep up with my specific turf. Under 'normal' conditions, in order to get a finished, clipping-free cut, I'm double cutting each mow, minimum once per week, ideally twice per week. During the early spring or wet weather, even that pace can leave the lawn looking unfinished (clippings, clumps) because growth is so fast. I've slowed down my fertilization and tried some different feeding techniques to keep the growth more reasonable, but my northern mix turf grows uncontrollably fast.
Even since I purchased the Fastrak, I've still wanted to demo a true commercial unit, to see if my expectations are too high or if what I'm seeking can be achieved with an even bigger/better mower. I don't know that I could ever justify the purchase price (even used) or the loss I would take on the Fastrak to upgrade. It seems the pros can rip through many of my neighbors' properties and have them looking good, once per week, with a fraction of the effort I'm putting out. Would a bigger engine, another half inch depth on the deck, a different deck design, and a wider discharge chute make a substantial difference? Not sure, but it would give me some confirmation as to whether it's my expectations or the mower that needs to change. Thankfully I enjoy lawn maintenance, but I do feel at times I've become a slave to the lawn.
Ultimately I think all of the Hustlers are very good mowers and there's enough variety and options with the different models to match each owner's needs and wants for value, speed, cut quality, etc.
