Raptor SD 933127 transmission brake seal kit
vmans1969
Does anybody have a part number for Raptor SD 933127 Brake Seal.
Hydro Gear does not sale the seal separately. You must order the complete seal kit PN 73107 (list price around $42). Now kit does list PN for the seals but which it is who knows beside HG. Some are metric and some are SAE.
vmans1969
Thank you, My Zero is leaking pretty bad. Both sides. I would assume that Have to buy two kits.
I also manage to run down which HG pn it is in the kit too since I had the kit on hand. PN 44761 superseded to 70719 if you wish to go that route now.
I be putting this info into my system here too for crossing later.
vmans1969
Yelp.
But just check here the seal is a TCM 060102TC. Here is a source for those 5/8 in ID x 1 in OD x 1/4 in W, Nitrile Lip, 70 Durometer seals. So you might be save some if they are the only seals you need.
https://hcisupplystore.com/104749/1189/power-transmission/seals/oil-seals/06102-tc-ipc-usa-company
Also available on Amazon
https://www.amazon.com/TCM-06102SCWY-BX-Rubber-Carbon-Steel/dp/B01BQHO7P4
No point paying a arm and leg just for a couple seals.
Thank you so much. That's all I need is the seals.
Your welcome. I just hate it when a company tries something as sneaky HG tried here. At least I took the extra time to find the seal actual pn on it here while I am rebuilding a ZT3100 here which uses the same seal kit. Now I can too just buy that seal when needed.
I just wish I could find the Dana seal I needing. Every vendor say it is on a ship out China. I think it must be one Chinese Junks with a slow leak and they bailing water constantly and it is slowing them down.
