raptor SD 26hp kohler
BamaMan66
battery is good, clicks when I turn the key on, but won't turn over, how can I check the starter or is there something else electrical
First, please post the model and spec numbers when you post back. That way we will know what engine you’re working on. Second, this is the procedure I taught my students when troubleshooting electrical problems.
Electrical problems can be very easy or very difficult, depending on four things.
1. How well you understand basic electricity.
2. What tools you have and know how to use.
3. How well you follow directions.
4. You don't overlook or assume anything and verify everything.
Remember we cannot see what you are doing. You are our eyes, ears and fingers in solving this problem. You must be as accurate as you can when you report back. The two basic tools we will ask you to use are a test light and a multi-meter. If you have an assistant when going through these tests it would be very helpful. These steps work the best when done in order, so please don't jump around. Now let's solve this problem.
First, check the fuse(s), check battery connections for corrosion (clean if necessary) and voltage - above 12.5 volts should be good. Check and make sure the chassis ground is clean and tight.
Second, check for power from the battery to one of the large terminals on the solenoid. One of the wires is connected directly to the battery and has power all the time so one of the large terminals should light a test light or show 12 volts on a meter at all times.
Third, check for power at the small terminal of the solenoid while depressing the clutch/brake pedal and holding the key in the start position (you may need an assistant to sit in the seat to override the safety switch). If your solenoid is a four wire solenoid, check both small wire terminals as one is ground and the other is power from the ignition switch. If your solenoid is a three wire solenoid, make sure the solenoid body is not corroded where it bolts to the chassis of the mower as this is your ground path back to the battery. If in doubt, remove the solenoid and clean the mounting area down to bare metal. If there is no power to the small terminal then your problem is most likely a safety switch, ignition switch or in the wiring.
Fourth, check for power on the other large terminal of the solenoid while holding the key in the start position (you may need an assistant to sit in the seat to override the safety switch).
Fifth, check for power at the starter while holding the key in the start position (assistant again).
Sixth, check your ground circuit back to the battery.
After you have gone through each of the above steps, let us know what happened when you did each step. At that point we will have great info to tell you how to proceed. Remember you are our eyes, ears, and fingers, so please be as accurate as possible.
Be as specific as possible with voltage readings as this will help diagnose your problem quicker. If you do not know how to perform the above checks, just ask and I will try to guide you through it. Youtube also has some videos and as you know a picture is worth a thousand words.
Welcome to the forum.
For those of us who do not have your particular machine in front of us it becomes a guessing game really quick what your problem could be.
Your machine has 2 important pieces of information that we will need to help you.
First is the machine product ID label information.
Second is the product label information on the engine. Kohler only built the engine, not the rider.
From there we can reference important information to better help you with this problem.
My small engine diagnostic "8 Ball" says:
It just "clicks" when you turn the key to crank it suggest a poor or corroded connection somewhere. Also, if it clicks, that indicates that the safety switches are likely working so it will allow it to crank.
How old is the battery and how did you test it?
A handheld test meter can read good voltage while not attempting to crank the engine. When you attempt to crank it, the voltage should not drop below 10V. If the voltage drops much more, the battery no longer has enough stored amperage. Voltage is only potential; amperage is the power to operate the starter.
