Cheapoldfart
- Sep 23, 2024
- 1
- 5
I have a cheap “Craftsman” rider. It seems to be considered the red headed stepchild of rider mowers based on multiple forum posts, but it does what we need it to do. Or, it did until now…
I noticed it was tearing the grass as much as cutting it, so I removed the blade and sharpened it. It gives a much cleaner cut, but it no longer catches any grass. I get maybe a couple fistfuls after mowing the whole yard, when I used to have to empty the bags at least twice.
The only change is the sharpened blade. Cut height is the same, gear and engine speed are the same. The mower sounds the same.
Does anyone have any ideas on what might be causing this? Leaving all the cut gras laying in a path behind the mower doesn’t look good.
Thanks!
Thanks!
