Well.....
the tranmission was in neutral after all, hence the free wheeling pulley on top. The shifting action is a little hinkey... Ill work on that. with things running and spinning, I bet it works better. No linkage adjustments, just a pivot point.
Still this did not explain my not being able to drive, it wasnt stuck in neutral after all. (I should also mention that although I lowered the deck with it running, it didnt cut a bit, the blades were not spinning very much.)
In anycase, moving on, I went on through the process of replacing belts. The drive belt actually looked very nice when comparing it to my new belt. No smoking gun there.
The engine pulley to variator belt also looks like it has very little lto no wear, although I have not removed it yet.
I got set to try and remove the engine pulley and guess what? The pulley spins on the shaft! I havent loosened the bolt yet. I can hold the shaft still with the ratchet on the bolt, then take the belts by hand and spin that pulley around
without the engine turning over.
Heres my smoking gun, why it would not drive AND not cut....the engine pulley is slipping.
I just did some searching and there is a keyway....someone left the pin out or it's sheared completely. I only have metric impatct sockets at home, gonna run and buy a 5/8 so I can get the pulley off.
Im gonna back up and tell the story I got told about this mower.....the guy I bought it from got it from his neihgbor who stopped using it.The guy I bought it from had bought new belts for it. So while he assured me the engine would run, I bet he knew it would not drive. (So he probably went out and bought new belts, but never got around to the job)
GIven the condition of the belts on there, Id almost bet the original owner put a set of belts on it, and left the keyway pin out. Frustrated, he gave it to his neighbor who bought a new set of belts for it again, but never installed them....2 years after that I bought it.
I love a good mystery. Its as much fun for me as fixing stuff----trying to figure out what went wrong!
So, not pleased the engine pulley is slipping, but happy I found a reason for it's symptoms.
