LawnBoyLanny
- Aug 29, 2016
- 1
- 3
Hello,
I am new here and would like to thank everyone. I have a 1990 Lawn Boy RE8e RER mower. I am curious to know what engine replacement options are available for my model, I bought the mower from a guy for $25, decent shape with a little surface rust, he said the motor isn't blown but the mower sat uncovered outside for 3 years, basically everything on the engine is trashed, carb, exhaust, various lines and connectors. Honestly, at this point it seems an engine replacement would be a cheaper option. It has the 8HP B&S I/C cast iron bore engine on it. Has anyone replaced their engine? Which motor did you use? What is the shaft dimensions on the stock engine? Any knowledge would be more than appreciated. Thank you for your time and understanding.
-Lanny
-Lanny
