PZT60 belt alignment issue.
beardenjt2
Can the PTO shift? My right PTO pulley is lower than the other pulleys in the belt system
What does the machine product information label say?
Has it got a running/ driving problem? Check the drive motor (PTO) mounting bolts on each side and make sure they are tight. Look for any cracks or breaks around the mount bolt areas.
