Push Mower runs then stops, then won’t start again.
Poulan Pro 500 E Series 140cc will run for about 10 minutes, then cut off and not start again. After it cools, it will start again, run for 10 minutes, then cut off. I’ve cleaned the carburetor and replaced the air filter. I don’t know how the choke works on this mower, but if it’s heat actuated, could there be a problem with the choke?
