Pulley/spindle squealing:Can they greased? (Badboy MZ Magnum 2014)
Possumphat
  • / Pulley/spindle squealing:Can they greased? (Badboy MZ Magnum 2014)
WILL ONE OF YA'LL TELL ME IF AN IDLER Pulley or spindle is squealing, is there a remedy?: Can they greased? If so how do I do that? (Badboy MZ Magnum 2014). There's SEVEN pulleys on that deck how do I find the noisey one?
JonnyBlaze
Some spindles have grease zerks, some do not. You'll have to check. Also, remove the belt or release the tension, and spin each pulley by hand. It's probably bad bearings in one of the pulleys or spindles.
