I bought a Kubota ZG123S today. I scratched around a lot of brands, coming down to the Kubota and Exmark.
A mulch rig is on order which will take a couple of days.
One stumbling block was the Kolher Courage engine problems. In fact, it almost killed the deal.
I have been lead to believe that most problem were with single cylinders and some problems corrected.
I was told that the ZG123S now has a commercial version of the Courage engine installed. I'm not sure this is true.
If it is true, then the problems are not solved if a commercial version needs to be used.
A lot of BS flying around out there.
