As you pull on the cord there is supposed to be a slight drag that causes the 2 pawls to extend out and catchHi I've got an older 6hp craftsman push mower. It starts right up every time but the pull cord doesn't catch! Any way of fixing it?
View attachment 26690View attachment 26691
that top part is the butterfly valve aka the throttle plate which when turned
counter clockwise increases the speed of the engine that screw that you messed with
when turned clockwise will increase the speed of the engine(idle speed )
that bottom screw that you didn't mention is the mixture adjustment screw.
If you haven't messed with it ......don't......If you have ....we need to talk some more :smile:
cheerfully,
Normf
