Pull chord stuck
mvanberkom
Recently, after using my lawn boy mower, I shut it off for a bit, and when I went to start it up again the pull chord was stuck. It would basically not pull at all. Based on a youtube video, I moved the blade back and forth and that loosened the chord up enough for me to start it again. However, next time I went to use it, the pull chord again is totally stuck after using it and shutting it off and trying to pull start it again. Anyone know what the problem is, and more importantly how to fix it so it does not keep occurring? Thanks for any help.
