Puff of smoke on start up and kill
PTmowerMech
Briggs 17.5 31C707 0603 B2.
On start up and when I kill it, I get a little puff of white smoke. It smokes a little more when I start it up. But it doesn't smoke for more than a few seconds. I'm pretty sure the valves need to be adjusted because I get a little bit of a stall when it's turning over.
Scrubcadet10
Moderator
Staff member
Could be valve seals or worn guides.
PTmowerMech
As in oil seeping into the combustion chamber, after the engine stops?
Scrubcadet10
Moderator
Staff member
Quite possibly.
Could just be rings starting to wear also
