manitowoc542
- May 26, 2016
- 1
HI. I have a 2020 Raptor SD 42. Usually after mowing a short while, when I disengage the blades, the pto rattles (it is a metallic rattle). I don't see anything obvious upon inspection. The black insulator that locates the clutch is in place and intact. The mower has about 15 hours on it. Has anyone else had this issue? I'm trying to avoid the pick up and delivery charges that it will cost if I want the dealer to take care of it under the warranty. Thank you.
