Hiya I have a Yardman HE 4160 the magnetic clutch on the cutter deck wont engage there is no voltage getting down. Also there is a display underneath the steering wheel which shows if the is battery charging, Brake on and cutter blades engaged, this does not light up at all either. I'm wondering could there be a common problem causing this, I have checked the main fuse but thats OK and mower starts and runs OK in all other respects. Thanks for any help you can give.
