I have an RZT50, that I bought in the 2004-2005 range. So far, I have replaced 2 PTO clutches, and one switch. Now, I seem to be having issues with the Reverse cutout switch.
I replaced the clutch yesterday, fired it up, and it mowed until I had to use reverse, then no more blade operation, and I no longer had the voltage to the clutch. I noticed before I replaced the clutch, that it acted intermittent after going in reverse. Since the clutch still will not operate with the application of voltage to the lead, I replaced the clutch. Now, I am suspecting an additional issue.
Can someone tell me WHERE the reverse cutout switch is located, and how I disable it? I have always disliked that particular feature anyway. Also, according to my owner's manual, mine is not working right anyway, as only the right lever cuts the pto out.
