dbonnell73
Engine info: Model 350447, Type 1084-A1, Code 95013011
I have an 18HP V twin in a homemade tractor that runs a hydraulic pump off of the flywheel.
The current adapter is held in place with two 5/16" bolts and I have repaired it twice (bolts broke). The adapter bolts to a modified flex coupling.
Is an adapter available that bolts directly to the flywheel or will I need to fabricate one?
Looking for something stronger that uses all 4 bolts available in the flywheel.
