neophyte_lawn_guy
- May 22, 2018
- 2
- 4
While I was cutting the grass my PTO dropped off the mower. I didn't realize what had happened till I saw it on the ground. A quick search of the lawn turned up the bolt and the fitting that holds the PTO to the drive pulley. I think I must still be missing a piece as there is no obvious way to connect the PTO do the drive pulley. The possible choice is just the friction pressure from the bolt, but that feels inadequate. How does the PTO connect to the drive pulley? The center hole of the PTO has a key in it, but there's no obvious shaft with a slot to take that key. I'm confused.
The Drive pulley, looking up, attachment point for PTO
Top view PTO, note key
PTO Bolt
PTO Bolt
