Hello I have a 2166 cub cadet, i mowed yesterday with no problems. Started today but clutch won't engage. I have power on both wires no matter pto switch postion. I disconnect the wires from clutch then i have power on one side, when i pull up the switch i have power on both sides. I believe that is the way its works. Do i have a bad pto clutch that needs replaced or is it something else. Thank you
