PTO actuator seems to loose vacuum intermittently
DanielT65
Have a 1999 Cub Cadet 3206 with a 62" mowing deck. Already replaced mower drive belt and blades, and both PTO belts. Sprayed vacuum line with starter fluid to see if it caused engine to accelerate, thus indicating a leak. No change. Same with rubber diaphragm on vacuum switch. Any other suggestion beside the obvious replacement of the vacuum switch?
