XTwarrior1985
- Apr 9, 2022
- 8
- 26
I had read this before, but confirmed this first hand. Rustoleum's Almond color in their Professional High Performance Enamel line is so close it is nearly identical to factory Cub Cadet Beige. Code is 7570 Almond. I did a quick spray over a rust spot on the inside of my 1998 Cub Cadet 2166 engine shroud. I am not sure what the Cub Cadet beige color code would be for this mower, but maybe someone can post it up and I can add. My mower code is 19512 13A-254G712.
The first pic in the sun it is impossible to tell, so the second picture under my shop light, I purposely took it at an angle that you can see where the rust spot is/was (just above the gloss shine). Hope this helps someone one day
