Need some Advice, I haes a 6 HP Tecumseh on a Troy-Bilt Econo-Horse Tiller it a 1990 model, All still Org. the recoil Pull Rope has gotten lazy about going back in, when i pull the rope most of the time it only goes back in about 1/2 way, if i keep messing with it, the rope will finaly go on in, i think there is a spring in there sort of like a mesuring tape, do i need to lube this sprimg with some Grathite Power or some other type Lube?or do you think there is something else causing my problem, Thanks for what ever help you'll can give this Old Man ( Good Lord Willing i will Make 75 in a couple Mo.)
Thanks
LakeRat1
Thanks
LakeRat1
