problem with gy20162 lower chute
zippahead63
i have a jd l130 with a bagger. broke the lower bagger chute gx20467 had to replace with gy20162 but cant get a tight fit on 48"deck. need some help or info thanks.
Looks like there is two different part numbers for the chute depending on serial number. Do you have the correct one.
063527 and above uses AM143912
zippahead63
when i ordered the chute gx20467 i was informed by many sites that it was replaced by the gy20162 chute. the old chute always went on like charm. but this one has a gap on top and doesn't fit snug.
zippahead63
not sure about serial#s didnt check on that
