Pappy 1954
- May 7, 2013
- 1
- 4
Gentlmen,
I have a 281016be rer snapper riding mower with elec start, 10HP B&S engine. It has been running good until 1 week ago. I turned the fuel line on and turned the key to start it. It cranked just fine. I could not get it to start. Then I could smell gas, like it was flooded. I took the air filter off and pulled the spark plug out and cleaned it. Still would not start. I don't think it is getting spark to the plug.
I watched some youtube videos on how to check for spark & how the magneto works. It also showed how to clean it. First I checked for spark with the plug...........has plenty of spark. Put the plug back in and it started right up. Yipeeee! Turned it off and now it won't start again. I unpluged the secret wire to disconnect the safety switches and it still will not start. Everytime I pull the plug, I have spark.
I did remove and clean the magneto. Brushed all of the rust off of the magnet. Re-installed the magneto with a business card spacing between the magnet. I get tons of spark from the plug. With or without the safety grounding wire.
Tonight I am putting in a new plug to see if that helps.
Any idea what it could be or what I need to check next if this does not help?
Thank you for your help in advance.
