gwtx
- Mar 27, 2011
- 4
- 13
I've had this "power unit" (which drives several attachments) for about a year and a half. Always ran good. Started having problems getting full power, starving for fuel. Figured the carb probably needed a diaphragm set. I've never heard of this carb before, it's a RUIXING numbers are "BED21153" and on the other side is "H6 C1". Dealer has no source for kit.(small town dealer). I've dumped the fuel, replaced the "fuel tank connection assembly", Cleaned the in tank strainer, etc. It will run a little stronger if I close the choke about half way, but not enough to run my pole saw. The exhaust is clear, the engine starts and idles fine, but if you quickly open the throttle, it bogs, and dies. I'm about ready to get an inverter,and run electric tools. Hate foolin with the blasted extension cords though.
Anyone have any info on the ruixing (chinese) carbs?, or any ideas to try.? ANY AND ALL HELP APPRECIATED. Gary
