Poulan Pro won't move
tyaddison
A friend has a Poulan Pro riding lawn mower which quit moving. The engine starts and runs. I tried moving the mower by pushing it after disengaging the transmission at the back of the mower. It would NOT budge an inch! Does anyone here have any experience with this same issue OR have suggestions of what to check?? Thank you all, in advance!
BlazNT
Check the brake. The way to check it is to kack up the rear end and spin the tires. If they moce in different directions then your brake is locked.
