Tiger Small Engine Lawn Addict Community Leader Joined Dec 7, 2022 Messages 2,294 Jun 1, 2026 #11 Tpieman22 said: have the correct schrader valve in tester Click to expand... Then you have really low compression. Can you post your results after rebuild so we can hear how it came out please?
StarTech Lawn Royalty Community Leader Joined Feb 19, 2020 Messages 14,577 Location Pluto Jun 1, 2026 #12 Then you definitely have a compression problem as it takes at least 100 psi for a two cycle to fire the fuel mix. You may simply have to replace the PNC again or called it too expensive to repair.
