Needing to replace fuel lines on a Poulan Wild Thing chainsaw. Anyone have a trick for getting a fuel line routed through the small hole in tank? I got the small line through, but the larger line just won't go all the way through. Tried pulling through using a piece of telephone wire looped through one end that was angle cut, but it just ripped through the line.
