Buying Advice Possible purchase of a ssv 22cv
cavmedic
I ran across a used ( best of my knowledge model # ssv -22cv )
The price seems good for something that needs a little TLC
I have not looked at the unit YET , but wanted to do some research first.
1.I am told the mower needs some exhaust work. ( looking at the pic, looks like a new muffler is needed)
2. needs a front wheel bearing ( pretty cheap repair)
3. deck makes some noise ( assuming it is the spindle bearings , and not terribly expensive)
4. Am told it starts and mowed fine ( did not egt an answer on hours or smokes )
5. am also told the hydraulics seem to operate fine.
This unit was a trade in to a shop and I am assuming they do not want to deal with a unit this old on their floor.
The price is right around $1,000. I'd have to drive about 1.5 hours each way to pick it up.
Is there anything else I need to be paying attention to , when and if I take a look at this unit ?
I am new to zero turns ( own older cubs and wheel horses)
Does this price seem to be ok ? Or should I run fast and far.
Thanks
Even if you have to stick another $750 into it, I think it would be a good deal. Things I would take a good look at. I am assuming that the dealer has not touched it. The first thing I would ask the dealer is "Why he does not want to stick money into it." If the reason seems off and the unit looks in good shape perk your senses to high alert. Price seems too good!!! If it has no major flaws (I'm thinking engine problems) check the following.
1. Look and smell the motor oil, hydraulic oil and air filter.
2. Check the pulleys on the deck for looseness and wear.
3. Check the blades, can be $$$$$
4. Check to see if the handles stay together when going straight forward and reverse.
5. If one wheel bearing is bad check the rest.
6. Check why muffler went bad.
7. If you have a compression tester, do a compression check.
8. After you figure out what you will have to replace, ask the dealer the cost of those parts. This will give you an idea of what it will cost you to repair.
Remember dealers normally don't give up a really good unit with out a reason.
